PXI 4351 and Labview RT: Failed to load shared library nicfq32.dll on RT target device
I have a problem trying to use a PXI 4351 card and labVIEW RT. When trying to download the code from the Host PC I always get the following Error:
Failed to load shared library nicfq32.dll on RT target device.
I wonder if this PXI 4351 driver is compatible with labVIEW RT.
Thanks in advance for any help
Gérald Schaller, metas
(4,391 Views)
Gerald,
Could you provide more information about which version of LabVIEW/LabVIEW RT and NI-DAQ you have installed on your host application and downloaded to your RT system. The 4351 requires the older "traditional" NI-DAQ driver, not the newer NI-DAQmx. Make sure you also have that downloaded on your LV RT system.
I just tried opening up a 4351 example in LabVIEW and downloading it to a LV RT system, and was able to do so without any error messages. I'm using LV/LV RT 7.1 and Traditional NI-DAQ 7.2.0f1. You can see the version numbers of your installed SW in MAX under the Software branch of your host system.
Christian L
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(4,391 Views)
