Alternative VIs for In Port.vi and Out Port.vi for 64 bit Windows 7 platform
Hi Need to use the printer port for my application. In Port and Out Port VIs was the simplest option in 32 bit Windows XP machine. Now I hear In Port and Out Port VIs are not supported in 64 bit Windows ( VISTA/7) machine. Is there any working alternative to In/Out Port.vi ??
Thanks in Advance
RKB
(6,518 Views)
Accepted by topic author banyal
The issue you have isn't a LabVIEW issue, but a Windows issue. The increased security was started with Windows Vista, and MS locks down access to the ports directly. There may be a way to get to those ports, but it would involve low-level Windows API calls. Haven't a clue as to what they would be - you'd need to Google for this.
What are you using the printer port for? Are you trying to use it as a poor-man's digital I/O?  If so, you're far better off replacing the implementation with a low-cost USB-based digital I/O.
(6,510 Views)
I wanted to use the Printer port for a 2-wire communication  with a temperature sensor IC. So yes it is bascially for digital I/O. Any idea if one can use VISA read/write for this purpsoe?
RKB.
(6,495 Views)
VISA can easily be used to solve your problem. If using a USB -> Serial adapter it's almost too easy. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(6,485 Views)
I am aware of that. But I cannot at present afford to purchase the Serial/USB adaptor. LV driver too comes free with the hardware...
RKB
(6,482 Views)
Hi !
Even am facing the same issue .Is it possible to read the  data through serial communication instead of using parallel port ?
My device is 64 bit Win 7 - LV 2013 SP1
sandy
(5,649 Views)
