NI 9476
Hello all:
I have 2 questions:
1. I am using the 9476 with a CB-37F-HVD terminal block. Must I set the Vsup channels in my LabVIEW program to TRUE for their respective digital I/O channels to allow for the supply voltage to be passed through the remaining I/O channels? Or is it energized immediately upon connection to a power supply (I suspect this because I don't see any Vsup channels in my project explore I/O list)?
2. I saw an older post on relays cycling in their ON/OFF states using the 9476. I am using a cRIO 9024. Any idea why this is happening? Overcurrent?
Thanks!
(2,916 Views)
1. Vsup is the power connection for the extermal power supply. I don't understand what you want to do in LabVIEW with Vsup
2. I would help if you add the link to that post. As long you do not use more current than stated in the manaul it should be no problem.
Kees
(2,874 Views)
