Unit test errror on RT target: VI under test is not broken!
I'm using the Unit Test Framework (LabVIEW 2012 no SP) on an RT target (cRIO 9074).
All items are on RT target (lvtest, setup VI, teardown VI, VI under test).
When I run the test, UTF returns with an error saying that the VI under test is broken. But it's not!
It seems to be a random behaviour. The test works sometimes. Sometimes the "broken" VI is the setup or teardown, but they're all not broken.
Any idea?
Peter
(2,799 Views)
Is there any code in the targeted VI that uses conditional disable structures to turn off or change code based on the OS or platform its running on? I don't use the UTF, but have seen this cause similar problems.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,784 Views)
What error message do you see when you click on the broken arrow of the VI?
could you attached the Screenshot ?
(2,744 Views)
(2,742 Views)
@ Mike: no platform specific code, no conditional disable structure.
@ ifnotdefine, itwilfried: again, the VI is not broken. UTF claims it's broken.
(2,715 Views)
