Am I commenting wrong?
billko wrote:
I've always used structure labels to comment.  On this machine, I have LabVIEW 7.1.  You just have to make the label visible.  Or is this handled in a better way in LV 2012?  Thanks!
Yes, you still have to make structure labels visible via the right-click menu.  In 2012, they added the Subdiagram labels, which Jeff has so eloquently shown.
Message 11 of 22
(2,079 Views)
I appreciate you guys' frank answers (Yes, that's wrong) but maybe I ask more exact questions -
Does the diagram disable structure make non-obvious changes to execution, such as forcing items in the enabled portion to execute around the same time the way the frame structure does?
Is the enable/disable operation determined at run time or compile time?
Is a formula node with no inputs/outputs visible at run time?
Is the text inside a formula node stored in some way that is less efficient than that in a free text label?
(And just to be defensive - the primary benefit of the formula node over the free text label is the scroll bar)
Message 12 of 22
(2,058 Views)
What about a string constant?  You can set the scroll bar to visible. You can have some "style," such as different sizes, bold, underline, and others.
Lynn
Message 13 of 22
(2,055 Views)
Does the diagram disable structure make non-obvious changes to execution, such as forcing items in the enabled portion to execute around the same time the way the frame structure does? yes
Is the enable/disable operation determined at run time or compile time? edit/compile
Is a formula node with no inputs/outputs visible at run time? not sure what you are looking for with this.  While a VI is running in the IDE, you can look at any part of the code
Is the text inside a formula node stored in some way that is less efficient than that in a free text label? there is the overhead of the formula node itself
(And just to be defensive - the primary benefit of the formula node over the free text label is the scroll bar) As noted, use a string constant
Message 14 of 22
(2,049 Views)
Thank you, crossrulz
If a formula node has no I/O, is it ever actually called? If I make an executable will it take up space?
Message 15 of 22
(2,035 Views)
Technically, since it is in the disabled subdiagram, it won't even be looked at for compiling.  But it does use up code space.
Even still, I would hate to have to toggle a case in order to figure out what the code is doing and then switching back to verify the comment matches the code.  I'd much rather have it all right there in front of me.
Message 16 of 22
(2,020 Views)
I think we are needlessly re-inventing the wheel.  Make a free label, then use decorations (like arrows or frames) if you need to clarify.  If you're like, me, the fewer the distractions, the better.  I'd concentrate on toggling between comment and code, and by then my i/o buffer has been overwritten.  😉
Bill
CLD
(Mid-Level minion.)
Message 17 of 22
(2,015 Views)
BTW, you should check out this idea on the Idea Exchange:Advanced Code Commenting Functionality
Message 18 of 22
(2,005 Views)
Accepted by topic author fborlc
In an executable with debugging disabled and block diagrams removed that would depend entirely on the version of LabVIEW you are using.  The 2010 - 2012 compillers should be able to optomize the code to completely remove the unreachable code.  In fact, the unreachable code will not be in the compiled code at all so there is no hit to the vi object only the source code will be impacted.  2009 may remove unreachable code.  8.6.1 and earlier will not.  Future versions I will not predict  and are subject to change this behavior for any reason.
FOR THAT VERY REASON, behavior dependant on LabVIEW version, I strongly urge you to discontinue this practice for commenting code.  some day it might come back and bite you in a big way.Smiley Surprised
Message 19 of 22
(1,997 Views)
Thanks for the clear answer, Jeff. I will use string constants instead for my long comments.
Message 20 of 22
(1,991 Views)
