Am unable to copy /paste portions of vi into another vi. Both 2012.
Trying to copy part of a vi into another VI      Acts like a screenshot when pasted   Won't drag/drop either.   Tried to move just a list box by itself.   Same result.
Wondering if anyone has run across?   Any idea's?
Thanks much
(3,619 Views)
Accepted by amazed
Try closing down Labview.  Do you have two different Labview instances running at the same time or is it all in the same instance?
Edit:  From what I can gather, each instance of Labview has its own internal clipboard and if you copy from one instance of Labview to another (different or same version number), the Windows clipboard is used and you only get a picture.
aputman
(3,584 Views)
Feel a little foolish - that had to have been the problem. I restarted the computer and its working now. Thankyou very much !
(3,578 Views)
