Amrel Error 1073807339 over Eth to GPIB
Our current test setup is using an Agilent E5810A to as converter to communicate to Amrel DCS.
Occasionally i got an error 107807339, to clear this error, is either by closing the program or resetting manually the equipment (Amrel) by toggling the power button switch.
Does anyone encountered same error or issue, is there a way the error can be cleared programmatically?
Tried to insert vi's - close, clear visa, but no lock.
Any recommendations?
(2,622 Views)
Have you tried the following KB: http://digital.ni.com/public.nsf/allkb/BF72229C53F7633386256EDD0069331B?OpenDocument ?
Hopefully that should solve your problem.
Jacob R
Jacob R. | Applications Engineer | National Instruments
(2,607 Views)
I dont want to ignore the error.
Apparently, once i got that particular error, i lost communication to the equipment.
(2,596 Views)
How are you communicating to the device?
I am thinking you should be able to do something similar to what the Reset Device VI does.
Are you able to communicate with the device after the error? Such as send it some commands or identifier? If you can, then maybe the manufacturer has some documentation on what commands you can use to reset the device.
(2,583 Views)
