RGB to color
Hello, my name is Jonas and I'm learning to use the program Labview and I have any questions about the function "RGB to color"
I was making some VI's when I decided make one which the user enter with the RGB composition and the program show the color, but I can't find the numeric indicator which show colors for connect to the function "RGB to color", cause if I use the "Color Box" always will be the error "You have connected a control to a control".
I look forward for your help
(3,038 Views)
Hello Jonas,
What if you make your color box be an indicator? Right click on it an chose "change to indicator". This could be the problem.
Regards
______________
Florian Abry
Inside Sales Engineer, NI Germany
(3,036 Views)
Post your code and we can see what your problem is and we can help much better.
Tim
GHSP
(3,024 Views)
Thanks, Florian Abry
You're right.
The problem is resolved
(3,013 Views)
