Stand Alone Application with VISA
Hi all
What exactly do I need installed onto a computer that I'm trying to run a .exe built from LabView 2011? The .vi that it comes from calls on a VISA and so currently I have LabView Runtime Engine 2011 and Visa Runtime engine installed on target computer.
The problem is that when I run the .exe it cannot locate the Visa. I've downloaded the VISA from National Instruments webpage and pasted into National Instruments\Labview 2001\instr.lib but no luck.
Any help would be useful
(3,211 Views)
That makes no sense. The VISA runtime engine would not be installed to that folder and you certainly would not paste it.
(3,203 Views)
Sorry, let me try to make it more clear
On target computer (which does not have LabView 2011 installed) I've installed the following things
-Labview Run Time Engine 2011 (LVRTE2011std.exe)
-Labview Visa Run Time (visa511runtime.exe)
The .Vi that I'm trying to change into a stand alone application observes an oscilloscope's waveform and does certain computation with it. I assume this means there is a VISA involved because the computer has to be able communicate with the oscilloscope.
When I run the .exe on target computer it is unable to communicate with the oscilloscope and gives me a message box "VISA Initialization Error". How do I fix this?
(The oscilloscope is a Tecktronix TDS 2001C )
(3,199 Views)
Your instrument driver in the program uses the VISA api for communication. It would help if you provided the actual error code but it seems like a problem with the installation of the run time engine. Install MAX so you can do some testing. Try a repair and even try installing the full version of VISA.
(3,196 Views)
