An error from DAQ,
The manual.
A screwdriver and take the screws off the top of the case.
Which SCC carrier are you using?  Is it the SC-2345?
Other questions:
Why are you having issues now?  Did something change?  New PC?
Why was that person allowed to leave without doing a better job documenting the system?
Message 11 of 17
(1,636 Views)
Screw driver is ready, cover is removed!
Yes, it is SC 2345,
I am so thankful for your time and help,
Message 12 of 17
(1,630 Views)
Yes, a power shortage caused some problems to the windows operating system. We had to re install every thing! I also installed a new version of DAQmx today. Previously it worked with version 8.7.1,
Good question. But now I have to learn things by myself. It is good, useful.
Message 13 of 17
(1,624 Views)
That stinks, but happens.  Learning more is definitely valuable.
Be sure to do what you need to do to get it working, but don't try to fix everything that looks like it could be fixed like modifying bad code.  If the code is bad enough, it might be so fragile that fixing it will break it.  Save any fixes and upgrades for the future once you have a working system to compare to and have a better understanding how it is supposed to work.
And be sure to help the next guy out who will follow you and do a good job documenting the steps you took to get it to work.
Message 14 of 17
(1,621 Views)
yes, right,
The code works almost perfect,
I upgraded it to a new version, with the help of a super genius undergrad student. And I have saved copies of that on multiple hard drives.
I downloaded the manual, and I am going to go through it.
Thanks for your help.
Message 15 of 17
(1,618 Views)
Thank you for your help. I went through the manuals and fixed the problem.
Now it works perfect.
Message 16 of 17
(1,601 Views)
Excellent!  Thanks for replying back to let us know it is going well.
Message 17 of 17
(1,599 Views)
