An error occurred loading VI. LabView load error code 1: LabView load error code %ld: %p”
I have been developing a VI file that has been working fine, until now. I am using 8.6.
Every time I attempt to open this file I keep getting:
How do I fix the error code:
Labview: Memory is full.
On a separate dialog:
“Not enough memory to complete this operation.”
I ran VI analyzer which told that the VI:
One or more errors occurred during analysis.
Testing errors tab – Vi not loadable and my file name. At the bottom in the error description I got:
“Error 74. Memory or data structure corrupt. <my file path> and <file name>.”
Could not be opened.
Is there anything I can do to recover the file?
Message 1 of 8
(8,177 Views)
That KB article applies to when you're running a VI, not when you're opening a VI, which is what the user is having problems with.
To poster: Your most likely problem is that you have a corrupt VI. I would suggest trying to open a backup, which you have, right? You could try to upload your VI to see if someone else can open it.
Message 3 of 8
(8,138 Views)
Hi
Is there an answer for this? i have the same problem...
Message 4 of 8
(7,169 Views)
As I indicated, the VI could be corrupt. Try opening a backup. Otherwise you can upload your VI and see if someone else can open it.
Message 5 of 8
(7,164 Views)
Hi there
I am having this same problem.  I don't have a backup of this code and was wondering if someone could perhaps try to open this file for me.
Message 6 of 8
(6,560 Views)
Hi kevin_khan,
I went ahead and tried to open it and got the error attached.
Peter T
Message 7 of 8
(6,517 Views)
Dear National Instruments,
Is there any solution to a "LabView load error code 1: LabView load error code %ld: %p”" type error ?
/søren jensen
Message 8 of 8
(6,080 Views)
