digits of precision limit to 3 significant digits
Hello!
I need 3 signifcant digits. If I choose 13 digits, it gives me 2 places. If I choose 14, it gives me all places. Can you please see the attached VI and help me? I need 3 decimal places. Is this possible?
Thanks 🙂
Message 1 of 23
(5,685 Views)
HI Susanne,
you need to choose a display format of "%.3f". Change the properties of the numeric control accordingly!
If you really insist on "3 significant numbers" you need to choose "%_3f", but all this is available in the control's properties dialog!
Message 2 of 23
(5,681 Views)
Thanks Gerd.  The numeric properties of a control doesn't show "%_3f". Where can I find/choose it?
Message 3 of 23
(5,670 Views)
In the control properties dialog!
In der deutschen Version ist das das "Anzeigeformat…", welches man entweder durch Zusammenklicken einstellt - oder über den "Fortgeschrittenen Bearbeitungsmodus"…
Message 4 of 23
(5,663 Views)
right click on the control, go to tab "Display Format"
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 5 of 23
(5,661 Views)
@gerdw hatte extra geguggt, ob du schon geantwortet hattest 😉
Message 6 of 23
(5,660 Views)
yes, I did that. and then?
btw: I don't have an control, it's an indicator but the properties looks the same 😕
Message 7 of 23
(5,654 Views)
Hi Susanne,
you surely don't want to "hide trailing zeros", don't need "automatic formatting" or 13 signifcant digits!
You wanted floats with 3 significant digits…
Message 8 of 23
(5,641 Views)
while you were posting, I found it - thanks 🙂
has this changing consequences for further calculations?
Message 9 of 23
(5,635 Views)
every numeric indictaor, control, constant has this tab
this is AFAIK only representation, but i am not sure
Message 10 of 23
(5,634 Views)
