An input parameter is invalid. NI 488: Command Requires GPIB controller to be controller in charge
Hi I'm trying to simulate a charge controller for an electrical vehical prototype. I'm using cRIO for communication between the charging station and LabVIEW.
A subVI for communicating with the charge control is attached [CC_control.vi]. I have the above mentioned error in the main program due to the CC_control.vi. The error occurs occasionally and ceases when I restart all the hardware.
Is it because the file is closed and opened again in the "Read all registers" case within the loop? What should I do to rectify this? [All the code was developed by a previous student].
(P.S. Some blocks might be missing as I could not locate the polymorphic VI in the same case.)
The main VI "tabs-FS.vi" (minus all the subVIs) is attached for reference.
(3,175 Views)
Hi shreya,
don't create double posts!
Let's keep things in one place!
(3,148 Views)
