How is work "Get Shared Variable List with another computer " ?
Hi all
I can't receive the list of Shared Variables from   another computer  .
From localhost computer I received it.
Why?
Regards
Iskander
(3,495 Views)
First the stupid questions...
Are you sure the variables have been deployed on the other computer?
Are you sure you have the right IP Address?
Could your IT department be blocking you?
Could Windows firewall be blocking you?
(3,493 Views)
The NI Distributed System Manager see this variables on another computer
The name and the IP are correct.
Best regards
(3,484 Views)
Hi Iskander,
I found a KnowledgeBase on the error you're receiving here:
http://digital.ni.com/public.nsf/allkb/96C5B8A73F624996862576CF00611A41?OpenDocument
Let me know if its solution helps.
John M.
(3,411 Views)
Hi John M.
Thank very match
I use the Search Variable Container Function
Best respect
Iskander
(3,297 Views)
