Analog Input Magnitude to Show on Front Panel Numeric Indicator
I am reading an analog input signal channel with multiple samples, and I want the magnitude of what is being read to be displayed on a numeric indicator that is on my Front Panel.  I know it is not possible to just wire the waveform data directly to a numeric indicator because of the difference in data type.  Does anyone have an ideal on how I can go around this?
(3,191 Views)
Accepted by Tebefia
Dear Tebefia,
You can use " Extract Single Tone Information " function found in signal processing palette.
You can find more info on this function Here
Regards.
(3,170 Views)
Dear NapDynamite
Thanks for the help.  God Bless.
Best regards.
(3,150 Views)
A kudo would be appreciated. 🙂
Regards.
(3,132 Views)
