Analog Input and Output
Hi Everyone:
I got a question for the example of Analog Input and Output that comes with 5640r.
I try to use the single Tone mode to generate sine waveform, it works really fine when I use scope to catch it.
However, the problem is when I change the sine waveform to square or triangle waveform, I can not get those waveform correctly.
For some reason, it still gives me sine waveform.
I am new to Labview, so sorry to ask this fundamental question.
Thanks for your help.
Austin
(3,725 Views)
can you post the screenshot of the VI?
what is the sampling info you are using to generate?
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(3,709 Views)
Hello!
Actually, there is a forum specifically for the IF-RIO devices. If you go post your question there, you'll be able to get great support for your device.
Thanks!
Ben Sisney
FlexRIO V&V Engineer
(3,677 Views)
Hi, Anil:
I changed the sinewave under Single Tone to square waveform.
Austin
(3,669 Views)
