Analog Out Error Help: AO Buffer Write Error Code -10687
I am Using PCI-6713 Card for ouptutting some data. The problem that I am running into is that when I run the VI for the first time it gives me "AO Buffer Write Error Code -10687" error. When I run the VI again it works just fine. I am using the buffered output AO_ContGen VI.
Can someone please tell me what I am doing wrong. I am initializing the buffer as well.
(2,739 Views)
may be it help you.
http://digital.ni.com/public.nsf/websearch/862567530005F09D862567CF007D8BDD?OpenDocument
Best Regards
TN
(2,739 Views)
