Converting .VI file from Labview 6.1 to Labview 7.0
I have .VI file that was working fine under Labview 6.1. However, after Labview 7.0 is installed, some of the subvis are not working. When I clicked into my .VI, it says it is searching for AI Read One Scan.vi. I also have AO in the .VI. So far, I could not find the new name or function of these two? Is there any way, I can have smooth transition from version 6.1 to 7.0? I do not want to find each question mark in the older version .vi to convert the new version of module. Any help, appreciated.
(2,517 Views)
It sounds like you didn't install DAQ support. There is a second CD called Device Driver Reference. Install NI-DAQ from there and see if that fixes your problem.
(2,517 Views)
