Analog Output Control Question
Hi anyone can help me? I am a labview beginner.
The system is driven by a sine wave signal from labview. My questions are as follows:
1. continuously compare pre-saved (dynamic) reference with current system signal;
2. Once they equal to each other, the system will give a half sine wave with another frequency, then change back to normal sine wave.
3. Every time, it happens, a half sine wave will be generated.
Anyone can give me any ideas on how to implement this? Many thanks.
(2,834 Views)
Hi yliu,
Can you give a bit more detail as to what you are needing. For example what aspect of the signal are you going to be comparing? Amplitude/frequency/phase ect....
In your reply explain the situation providing as much detail as possible, that will allow me to give you the best support I can.
Regards
Richard S
Certified LabVIEW Associate Developer
National Instruments UK&Ireland
(2,781 Views)
