how to synchronize RT target with host VI
I am running a code on an RT target that produces approximately 7MB in every 1024ms. If I send this data package through TCP from the RT target to the host computer, how I can be sure that the host VI reads its network variable exactly at that moment when it is sent over?
 At the moment I run the application in two steps, at first I start the host VI and then I start the RT target VI.
Is there a more sophisticated method to run the RT application+host VI programmatically? Also, how to synchronize the RT target with the host VI?
Krivan
(2,898 Views)
Can I get some assistance on this topic please.
(2,865 Views)
(2,851 Views)
If you can use LV2010 then use Network Streams, otherwise consider making your own tcpip communications vi.  I would package up the data with a SOF,Payload, EOF, CRC and then require the receiver to return a verification message to complete the transfer.
(2,837 Views)
