Analog input voltage
I have been trying to follow chapter four of the tutorial given by getting started manual. I have LabView 7 express installed and NI-DAQmx 7.0.1. Each time I select voltage (or any other analog input option), the computer will freeze out as if it's always been running. Can someone please explain why this is happening?
(2,896 Views)
Hi Angelia,
This is odd, what is the name of the example vi you are using?  Do you happen to have Measurement and Automation Explorer(MAX) installed on your machine?
Regional Account Manager
NI
(2,875 Views)
