Excel report generation
I am looking for a simple solution to this simple problem:
I have generated an excel data file using LabVIEW Report Generation Toolkit for Microsoft Office ( see diagram below ).
Now I would like to add data to this worksheet every time I run this VI ( data must expand in column format instead of
row)  but i have no Idea how to do it .
I would appreciate any help.
(2,772 Views)
Nobody knows how I could do that ?
(2,745 Views)
That's what the start input is for. You tell it where to insert the cells.
Asides:
  • Why aren't you wiring the error out from the new report function to the next function?
  • Do not autoindex an array and wire a value to N. Do one or the other, not both. If you do both the loop will run for whichever value (N, or the array size) is smaller.
  • Your loop with the function node can be simplified by replacing it with a single Divide function and feeding the Divide function the arrays directly. The numeric functions (as well as many other functions) are polymorphic.
To learn more about LabVIEW it is recommended that you go through the introduction material, tutorial(s), and other material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
(2,738 Views)
