Analog pulse analysis using piecewise linear regression
Greetings - After much experimentation I have concluded that the standard waveform pulse and transient meaurement vi's in LabVIEW are not adaptive enough to handle analysis (High, Low, Tf, Tr and Pulse width) for a generalized pulse that can be rectangular or in some cases triangular with zero pulse width.  I am thinking that the solution might be a type of piecewise linear regression.  Has anyone accomplished this without making any assumptions on the number of linear segments in the waveform? Is there another way to try to model this?
Message 1 of 1
(1,729 Views)
