change Startup RT in sbrio using remote support
hi,
I need to change the Startup RT in sbrio. but, sbrio is connected with another PC. I trying to change the Startup RT using remote support.
how can i change the Startup RT.
Give me some solution for changing the RT..
(1,275 Views)
Not being able to change the Startup routine unless you were directly connected to the sbRIO sounds like a very sensible Security setting -- I would be reluctant to mess with it.
Bob Schor
(1,222 Views)
Thanks for the reply,
can i use network browser for changing startup RT like copy and replace.
(1,205 Views)
