Analysing image to quantify liquid area
I am analysing acquired images of vessels containing liquid. I wish to quantify the area of the image that is air or bubbles. I would like to trace a boundary around the bubble or bubbles but I am finding it difficult to perform this with IMAQ vision.
I have enclosed 3 test images and would like some help on how to do this. I have tried the verticl clamp and curve extraction but I cannot get an outline of the bubble.
Any help would be greatly appreciated.
Simon Orchard MSc
Message 1 of 13
(4,697 Views)
Hi Simon,
You can try to binarize the image, then use particle analysis VI(s) in NI Vision to get position, area, perimeter, etc.
Message 2 of 13
(4,644 Views)
Thanks, but I have tried this and have not really had a lot of success getting a pixel area value, can you demonstrate??
Simon
Message 3 of 13
(4,642 Views)
Hi Simon,
attached you will find a Vision Assistant 8.2.1 Script, which gives you back the Areas of the bubbles!
Best regards
Alex Rudolph
NI Switzerland
Message 4 of 13
(4,578 Views)
Alex
Thanks but the zip file contains only the images I have posted here already and an SCR screensaver file.
Please actually send the Labview code
regards
Simon
Message 5 of 13
(4,560 Views)
Alex
I only use Vision Assistant 8.0.0. Can I have the script in this format
Many Thanks
Simon
Message 6 of 13
(4,559 Views)
*.scr is not a Screensaver, it´s the extension of a Vision Assistant Script File.
Attached you will find one for Version 8.0
Best regards
Alex
Message 7 of 13
(4,550 Views)
Alex
Thanks however the script does not analyse the bubble. It analyses the white spots on the image. I have been able to this so far.Tthe bubbles are the items with a thick black border around them and I am having trouble detecting these as the border of the vessel is at the same contrast level.
regards
Simon
Message 8 of 13
(4,539 Views)
I also thought the white spots were bubbles.
If the posiiton of vessel in images is fixed, try this way:
* acquire an image of the vessel without any bubble as a background image,
* binarize all images including the background image
* do subtractions between binary images with bubbles and binary image of the background
* fill the particles
* some other morphorlogy operations may be needed before or after filling.
* particle analysys
Good luck,
Message 9 of 13
(4,525 Views)
Thanks but I have tried all of this and cannot get a solution correctly. Thanks again but it looks as if i need to look for help elsewhere
regards
Simon
Message 10 of 13
(4,521 Views)
