Angular Position Measurement of a Stepper Motor
in a pretty complex VI, I want to generate a continuous pulse train in order to drive a stepper motor.
Next, I want to stop the pulse train when the stepper motor reached a certain position. Therefore, I want to measure the position of the stepper motor using an angular encounter.
To minimize the probability of software errors, I used the example for angular position measurements to post it here, as I have the same problem as in my program:
When I run the pulse train very slowly (around 1 Hz), the "data-indicator" alternates between 0 and 0.75 each step: 0  0.75   0   0.75   0 ...
From my understanding, I should be getting an increasing number, as the angular position increases with every step by (in my case) 15 degr.
I cannot really understand the alternation.
Thanks for any help.
(4,012 Views)
Let's ignore the pulse train for a moment.  Can you connect the encoder on its own and test it out, rotating the shaft by hand?  When you do this, does it read properly?
(4,006 Views)
Thanks for the answer.
Now I just used the "measure angular position" example, and turned the motor by hand.
Here the results for the different decoding types:
X1: nothing (stays at 0)
X2: nothing (stays at 0)
X4: the result described before: alternating between 0 and 0.75
2 pulse counting: the values decrease continuously... So I get negative values for both directions! One full rotation gives me something like -6xx in either direction.
Really confusing. I wired channel A and B to PFI0 and PFI1 on my USB 6211.
Thankful for any hints.
(3,990 Views)
I tried the same thing with the MAX. Creating the task, running the test. Same results.
I don't understand where my mistake might be. I turn the motor by hand, I checked the wiring. Smiley Frustrated
(3,976 Views)
If you have not already read "Encoder Measurements: How-To Guide" you may find it helpful as a starting point.  Sounds to me like a wiring problem, or possibly a bad encoder.  I assume you are not using the Z index, and that in addition to the A and B channels you've connect a ground reference.  I would check the A and B channels independently.  You could do this by setting up a simple DAQmx counter task for each channel and see if it counts up as you rotate the shaft.  You might also catch the pulses with an oscilloscope, or with a multimeter if you rotate the shaft slowly.
(3,975 Views)
I tried the independant counting before:
Using channel B - I can count probably,
however, channel A does not work.
From my understanding it sould do the same just 90 degr out of phase as opposed to channel B (?). If that is correct, I think a faulty encounter is the only way I can explain the issue...
(3,972 Views)
