Animatics Class6 Smart Motor Code
Anyone have some suggestions on the correct way to create a Labview program with Class6 Ethernet smart motors. Maybe some example projects. In the Animatic manual it mentions to add thru SMI and ActiveX but there is no further guidance. Thanks
(1,805 Views)
I've worked with some Animatics motors in the past, a long time ago.  I'm under the impression that you can just send commands to the motor via RS-485.  You'll need a RS-485 interface for your PC, if you don't have one already.  Other option is to use Ethernet/IP.  However, Ethernet/IP over LabVIEW is a little more complex ... I don't know the details, but you can check out this thread:
https://forums.ni.com/t5/LabVIEW/Ethernet-IP-Communication-Using-NI-Industrial-Communications-for/td...
I'm basing my assumptions for available communication interfaces from page 5 of this datasheet.
https://s3.amazonaws.com/www.motionusa.com/animatics/Class_6_Industrial_Ethernet.pdf
Command list here (it has examples too):
https://www.animatics.com/content/dam/acquisitions/animatics/literature/manuals/programming-informat...
(1,748 Views)
This is a Ethernet smart motor. I was hoping someone had figured this out in more detail with maybe some examples but Im getting into it now.
(1,730 Views)
