Annual Ring of Tree Counter using IMAQ Module
I wanted to make a program that can count the number of lines specially  the annual rings of tree, But I don't know how to start the program and what functions to use. I prefer using I M A Q module because it's the only one that's appearing on the internet that has similar connection to this project.
Question is, is it possible to count the annual rings of tree using Lab View? how can I do this?
(2,467 Views)
I believe that the answer to the first question is "Yes, with a suitable Image".  The answer to the second question depends on your level of knowledge and experience in LabVIEW.  If you have several years of experience, and some knowledge and experience with Image Processing, then you probably know the techniques you'd need to do this.  Otherwise, either (a) spend the time to learn LabVIEW and Image Processing, or (b) hire someone with this experience.
Bob Schor
(2,433 Views)
