FT245R D2XX drivers
Hello I'm using FT245R to send data from an FPGA to PC. I'm using labview to read data.Particularly I'm using the function Write-Read Byte Array Demo.vi (with a modification to read large amount of data). From PC i send a command with the number of data I want to read (this data are all 0, it is an example just to try)I have this problem: If I want read data bytes < 63488 i have no problem (i can read the buffer with only one reading cycle). If I need to read data > 63488 (more then one reading cycle) I have some data lost.I attach the labview function I use.
From PC I send 16 bytes of comand in wich I indicate the number of 0x00 i want to read (for example I indicate I want to read 65536 bytes 0x00). Then I wait for read: in the case of 65536 byte , in the first reading cycle I read 63488 bytes (max buffer size), in the second i should read 65536-63488, instead some data are lost (the amount of data lost is variable).
I Hope you can hel me.
(4,336 Views)
Hello, is your problem solved, i know it is an old thread though. But i am having problem reading from the FT245R D2XX using the sample code , can you give me any help?
(3,199 Views)
You need to be more specific about what the problem is you're experiencing.
(3,193 Views)
I am having the program hooking, and the computer stops working completely
(3,179 Views)
I mean a lot more specific. Can you attach your code?
(3,173 Views)
