Antenna design
I want to design an antenna for my final year project.
I am familiar with LabVIEW and hardware like sbRIO and myRIO.
I will work on these hardware boards for my project.
But i need help for designing the antenna with or without LabVIEW.
(3,340 Views)
Hey Icedemon72,
I would advise describing in greater detail what you are asking for and some design requirements. To get valuable responses, you must first post valuable information. Hopefully from there, someone on the forums can assist in gernal antenna design questions.
Tannerite
(3,335 Views)
Your design will likely take place primarily outside of LabVIEW.  Have you seen software like this: http://www.eznec.com/ ?
You'll need to figure out quite a bit more than the software.  What style of antenna are you planning to build?  What frequencies do you want to see?  Etc.
(3,298 Views)
