Any Energy Meter with Labview
Thanks for all replay,
Now i have received power meter Lovato DMG210 which have RS485 port. i test to read its holding register using modbus poll software. i am using RS485 to Ethernet converter (picture attached) i configure converter baud rate and other setting as power meter so became able to see data on modbus poll software.
now i want to read this meter data on LabView. i never used modbus in labview but just read some documents which shows LabView provide three types of modbus communication. as describe here:
https://www.ni.com/en-lb/innovations/white-papers/12/introduction-to-modbus-using-labview.html
as i am knew so i want to use easiest way to communicate with energy meter.
what method should i use for this.
asif
Message 11 of 12
(2,040 Views)
Accepted by topic author Asif138
Thanks every one for your support,
i finally configured LOVATO DMG-210 power meter using modbus liberary and succeed to read its register values.
thanks.
asif
Message 12 of 12
(1,728 Views)
