Any alternate solution to using Waveform Chart Property Nodes 'ActPlot', 'Plot.Visible' for mulit-plot color problem on PDA?
    On a waveform chart, 4 signals need to be plotted based on the status of 4 boolean inputs. Eg. if the first boolean input is true, the first signal needs
to be visible on the waveform chart; if the first boolean input is false, the first signal should not be visible on the waveform chart and so on. This can be
done on LabVIEW desktop using the Waveform Chart Property Nodes 'ActPlot', 'Plot.Visible' - a sample VI "BundleSignals_Select_Desktop.vi" is attached for
reference.
    But on PDA, since the Waveform Chart Property Nodes 'ActPlot', 'Plot.Visible' are not supported, some other method has to be used. I have done the
selection/de-selection of these signals using 'Insert', 'Delete' array functions as shown in the attached VIs "BundleSignals_PDA.zip" which works, but the
problem is that the colour of these signals do not work as desired when the selection/de-selection of these signals is done - It is required that the first
signal should always appear in White color, the second signal should always appear in Red color, the third always in Green color & the fourth always in Blue
color.
    I hope i have made myself clear of the problem. Has anyone faced this problem before & is there a solution?
Note: Version of LabVIEW that we are using: LabVIEW 8.5 Professional Development System for Windows Vista/XP/2000 and LabVIEW 8.5 PDA Module for Windows
Mobile.
Thanks & Regards,
Subhashini
(3,636 Views)
Unfortunately the only alternative to using property nodes is to set the properties manually on the development environement. The limited size of memory does limit us in terms of features for the module.
Mehak D.
(3,532 Views)
