Any experience with LabView on Linux?
Hi folks,
is anybody out there with experience with LabView on Linux? Or is
there a FAQ? My concern is mostly assigned to "talking to
hardware" vie serial ports under Linux. With GPIB card drivers
for Linux I don't anticipate too many problems...
Thanks in advance - David.
(3,733 Views)
Hey David,
You shouldn't have troubles if there are drivers and you are using the proper distro. Personally, I prefer Scientific Linux 5.5 since it has been the easiest to deal with of the distros I've tested, and the VISA drivers you will need for serial are fully supported. Hope that helps!
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(2,994 Views)
