Any suggesstions on how to manage 100+ indicator and containers
Where is the Preferences dialog? Or did tst mean the VI Properties dialog?
- Partha ( CLD until Oct 2027 🙂 )
Message 21 of 23
(2,052 Views)
Since there was a listbox mentioned, I'm pretty sure we are talking about the options dialog (Tools->Options).
The VI Properties dialog uses a ring and a subpanel.  So the concept is still the same.
GCentral
Message 22 of 23
(2,045 Views)
Like crossrulz said, the two work in basically the same way, but the general preferences dialog uses a listbox. There should be an example on LAVA (I think Jon Green posted it in the CR) which shows how to add pages to the preference framework. If I remember correctly, the framework itself is password protected (the code for it probably somewhere in the LabVIEW\Resource folder or in vi.lib), but I think that some version of it should also be available as an NI labs download.
___________________
Try to take over the world!
Message 23 of 23
(2,039 Views)
