Anyone has ideas about "Invoke node - attachdatasocket" , how to use it in edit mode. Could you give a simple example?
I'm trying to bind network variable by attachdatasocket, but it always failed. Anyone has good ideas about "Invoke node - attachdatasocket" , how to use it in edit mode. Please clarrify it. Could you give a simple example?
(2,241 Views)
This method is typically used at edit time, meaning you configure the binding when the VI is not running. Here’s a simple example of how you might use it:
Open your VI in edit mode.
Right-click on the control or indicator you want to bind to a network variable.
Select “Create” > “Invoke Node” > “attachdatasocket”.
Wire the reference of the control or indicator to the Invoke Node.
Configure the properties of the Invoke Node to specify the network variable path.
Here’s a basic code snippet to illustrate the steps:
// Assuming 'controlRef' is the reference to your control or indicator
// and 'networkVarPath' is the path to your network variable as a string.
// Create the Invoke Node for 'attachdatasocket'
InvokeNode attachDataSocket = new InvokeNode(controlRef, "attachdatasocket");
// Set the network variable path
attachDataSocket.SetInput("networkVarPath", networkVarPath);
// Execute the binding
attachDataSocket.Execute();
Please note that the actual implementation may vary based on the specific version of LabVIEW you are using and the context of your application.
Best Regard,
angela683
(376 Views)
