Anyone have experience of validating Labview in a medical application?
As the title says, I'm trying to find how to validate a LabView application used in a medical product.
There is endless information on the web about the theory, but I'm looking for the actual nuts 'n bolts of doing it. NI do sell some tools but they are pretty expensive.
Does anyone have any examples of what you actually need to do?
Andrew
(3,977 Views)
Hello Ash,
Personally I have no experience with this. As far as I know, even if a VI/SubVI/Express VI shipped with LabVIEW does already have some certification, it normally needs to be re-certified as part of the particular application you create with it.
However, I assume that the regulations for this vary from country to country. Where are you based / which country or market are you targeting your product?
I found some guides and threads on this topic; had you already seen them?
Apart from this: Do you know there is a Biomedical User Group on this forum? Maybe someone there has done this before.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(3,925 Views)
Not Specific to any Add on Tools, But in LabVIEW Environment i have developed n number of Applications which involves testing of Medical Products (X-Ray Generator, MRI Scanning, Etc.,)
Not sure about your expectation.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,916 Views)
Thanks very much for all those links. I'm sure there will be something helpful there. At the moment, the equipment is going through BSI safety testing but we will then be looking to put it through FDA.
Cheers
Andrew
(3,869 Views)
Hi were you able to find the needed resource for FDA
(3,419 Views)
