What is the difference between HTTP POST and PUT method?
Hello everyone.
Due to my previous post https://forums.ni.com/t5/LabVIEW/Same-switch-but-different-programs/m-p/3925587
Now my web application (BL1.1W Web Application NXG\WebApp.gcomp\Function_4.gviweb) is using the HTTP POST method to send the value back to the shared variable. But when I press the pause/resume button from the web application, the dummy program doesn't change accordingly. What I want is when I press the pause/resume button from one program. Another program will update the settings accordingly.
I want to know how the difference between HTTP POST and PUT method. In this case, what should I use?
Thank you in advance.
(3,580 Views)
https://restfulapi.net/http-methods/
POST to create.  PUT to update
(3,567 Views)
Thank you so much for answering me.
I'm a beginner for LabVIEW. Do you have a sample to use HTTP PUT method?
(3,542 Views)
