Anyone know how to connect a 3 wire magnetic sensor using an scxi 1126 with a TBX 1328?
I am trying to measure 1750 and 3600 RPM @ 60 hz using SCXI 1126 TBX 1328.
(2,612 Views)
Hello;
I don't know the details about that particular sensor, but as long as the sensor gives a voltage signal, you can use the SCXI-1328 Users Manual to double check how the connections are made.
You can download the Users Manual from NI's home page.
Hope this helps.
Filipe A.
(2,612 Views)
