My Labview-program works and I recieve data until it suddently crashes.
I have a serial device that I'm acquiring data from. My Labview-program works and I recieve data until it suddently crashes. I don't know why.The program continues and gets data but it is obviously nothing but trash.
(2,723 Views)
Keiner,
Can you provide more information on this issue? Or you can create a service request at http://www.ni.com/ask and choose either phone or e-mail.
At what point is it crashing? Does it happen at the same point/time each time you run the application. What version of LabVIEW are you using? Are you using VISA? Which version? Or are you using the old serial VIs? Are you using RS-232 or RS-485? Thank you.
Randy Hoskin
(2,723 Views)
Did you find any solution for this problem?
I got labview DSC 6 and PC anywhere install on my computer. The system sometime crash want I do a logoff of the program. I use a RS-485 serial card. Fieldpoint 3.0.1 is also installed on the computer.
(2,723 Views)
