Anyone know why when I print a graph it will print the graph without the plots?
I'm attaching a picture to show what I mean, as this seems like a weird problem. I've never seen this before, and not sure when it won't print the plots. Anyone happen to have any idea why, or a way to fix it?
Message 1 of 15
(3,663 Views)
What method do you use to get the image? Get Image of the VI?
Can you make an isolated example of the problem? It's hard to say if it's a bug in your code, NI's code or a feature.
Message 2 of 15
(3,631 Views)
It doesn't seem to matter how I do it. For the snippet I posted I just went to file print. The button I have uses the Easy Print VI Panel. It use to print it off, which makes it even stranger I just noticed it happening today when I went to print off the tab. The only thing I've changed since it worked was the size of the lines.
Message 3 of 15
(3,618 Views)
Is it reversible? Might be fairly easy to isolate it. It could be a combination of line colors, background colors, widths, etc.
Message 4 of 15
(3,601 Views)
I've tried changing about every option you can think of changing in how the graph is displayed. No matter what when you go to print the graph is empty. It just acts like the data is not there, and it makes no sense at all.
Message 5 of 15
(3,586 Views)
To recap:
The graph itself shows the plots, but when you go to print the graph, there are no plots on the printout.  Is this correct?
Bill
CLD
(Mid-Level minion.)
Message 6 of 15
(3,571 Views)
What happens if you try to print it a second time?  (Without doing anything in between prints.)
Bill
CLD
(Mid-Level minion.)
Message 7 of 15
(3,566 Views)
Correct. When running the VI the graph shows all the plots just fine. When you print the graph, regardless of how you print, it prints the grid lines of the graph but the actual plots are missing. The rest of the data on the tab that is being printed is all printed fine as well. It is just the plots that aren't appearing.
Message 8 of 15
(3,563 Views)
I just tried printing twice without changing anything between, and both printed without any plots on the graph.
Message 9 of 15
(3,558 Views)
Weird.  I cannot explain it, except that it appears to be graphical in nature - i.e., the plots are actually there, but they are invisible.
Bill
CLD
(Mid-Level minion.)
Message 10 of 15
(3,551 Views)
