Remotely debugging Executables block diagram in labview
Hi, In one side, I run the executable on the machine PC (labview 2016 32 bit) and in other side, I want see the block diagram remotely with the developper PC (labview 2016 32 bit). So, in Advanced properties I have check the Enable debugging. Then, I can remotely control the executable but when i'm suppose to right click on it and see "show block diagram" or "quit debug session"... I didn't see anythings.
Somebody knows about it?
(3,246 Views)
Can you connect remotely? If not, can you connect to the executable from LabVIEW when on the same computer?
Once you are connected from LabVIEW to the executable, you need to go to the Window menu and select "Show block diagram" or Ctrl+E.
You need to select Enable debugging before compiling the executable. However, even then, each VI that you want to debug must have be compiled with the option "Allow debugging" in the Execution category of the VI properties.
Marc Dubois
(3,228 Views)
Thank you for your answer.
Yes, when I desactivated the anti-virus, I can connect remotely. I can control from a other PC, but I'm supposed to right-click on the main page to choose "Debug block diagram" or "Quit". But it doesn't work.
I did check the selection "Enable debugging" before compiling the executable. I also check the option "Allow debugging" in the Execution category of the VI properties.
It still not work...other Idea?
(3,187 Views)
