03-13-2006 11:16 AM
03-14-2006 04:28 AM
Hi ianhf,
Try adding a commit after the Generation Session's niHSDIO Export signal function? Unfortunatelly I don't have the software installed on my machine to try this yet.
One of the error codes actually ports to DAQmx error -200586 "If you are using an external sample clock, make sure it is connected and within specifications."
How is your clock connected? I'm going to take a better look at your settings and see if there is anything wrong with them. In the mean time if you could check your settings and the connections. We'll be in a better point to solve this.
Thanx
AdamB
03-14-2006 07:34 AM
Hi
Bit of a boob, the reason i am getting unknown error message is that i was using wrong function panel. Hence didn't recognise code.
However, i am now getting error 200586 - External sample clock not connected or not in specification.
I am sourcing the external clock from a digital output from the generation side. I have tried committing the digital pattern but it doesn't seem to have any effects.
Any suggesttions
ian
03-14-2006 08:58 AM - edited 03-14-2006 08:58 AM
Message Edited by Ryan M on 03-14-2006 09:00 AM
03-14-2006 10:16 AM
03-14-2006 10:53 AM
03-15-2006 05:19 AM
Hi Ryan
Thank you for the advice. I will modify my test board to use DDCclkOut, start trigger and pause. I think this will work.
Ian
03-17-2006 06:57 AM
Hi
Thank you to all who gave advice i have now got the 6541 doing exactly what i needed.
I have exported the DDCclkOut pulse to Strobe, added to new digital lines for Aquisition Start and Pause.
I can now gather just the bits of information i needed and ignore the unwanted section of the digital pattern using the Pause triigger.
Ian
03-17-2006 08:09 AM
