Hello I have a problem if I write a caption identifier about property node the error 1073 occurred.
Could me help someone with this problem?
(3,202 Views)
Which version of LabVIEW are you using ?
Could you post your VI so that we can try to reproduce/understant/fix this problem ??
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,197 Views)
What do you mean with identifier? Are you sure you are not writing the Label.Text property instead? Label text is read-only.
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,194 Views)
About LV 7.0 or there-a-bouts LV started returning an error if you wrote to the caption for a control that did not previously have a caption.
Once the caption was shown (created) the error no longer occurs. I think the work-around was to just show the caption at least once and all is good from that point forward.
Not a bug, just a change in behaviour.
Ben
(3,176 Views)
It started with 7.1 and I never really understood that because if the reference was passed to a subVI it would work OK if you ran the calling VI and then ran the subVI, even if you never made the caption visible.
___________________
Try to take over the world!
(3,170 Views)
