02-26-2007 11:56 AM
02-28-2007 12:10 AM
02-28-2007 11:06 AM
Matt, Thanks for the response.
I tried simplifying my problem by creating a new project in 8.01 with a very simple top-level VI that doens't call any subvis. When I try to create a dll build specification, I see the following error:
"There was an error in invoking the build rule editor. Please check the corresponding provider directory to see if any VIs are broken."
and then a dll build spec with an empty name is created (see attachment). It seems like I need to recompile the app builder vis maybe? I have recompiled my entire LabVIEW 8 directory, are these VIs somewhere else? I do not see the error when creating an .exe build spec.
02-28-2007 11:27 AM
Matt -
I opened every VI in the AppBuilder folder and found the following VI is broken:
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\AppBuilder\ABAPI Build Shared Lib With Old Proto2.vi
Seem to me to be a fairly likely candidate to me. I'll try copying this from another one of my machines (that works) and see what happens. It's password-protected, so I can't see where the error is. It shows up as a wire type conflict in the error list.
02-28-2007 11:48 AM
Last update -
Have an AppBuilder directory with no broken VIs now, but I get the same error. Exe, installer and zip file build specs all work as expected.
Any help would be apprecitated. Thanks.
04-20-2007 02:33 PM
04-20-2007 03:46 PM
2and4 - I never figured out how to get this to work. Anytime I want to build a dll in LV8.01, I now use a co-worker's machine.
Good luck, and post here if you find the answer!
04-20-2007 08:35 PM
VITuning, I actually had the problem with LV 8.2. Very strange. Thanks for your help though, and good luck.
10-12-2007 02:43 PM
10-12-2007 03:15 PM
