App is looking for old version of runtime engine
I have an app that came with a datalogger that was (presumably) written in Labview 7.X. Whe it runs, it wants me to point it to lvruntimeeng 7.1.1.
I have LV 8.2 already on the machine, and I can't find the file it's looking for.
I really need to use this datalogger.
Any ideas?
Message 1 of 21
(5,116 Views)
Download and install the 7.1.1 runtime engine. It can coexist.
Message 2 of 21
(5,111 Views)
You know, I thought that would work and tried it first. When I tried to install the 7.1.1 runtime engine it errored out, saying I had a newer version installed already. But the app wants to see this particular version. Arrrrrgh.
Message 3 of 21
(5,090 Views)
I had the same problem before.  The installs often corrupt each other with 7.1 runtime engines.  Check this out:
http://digital.ni.com/public.nsf/allkb/680E61A4D02158A186256F7A0073C228
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 21
(5,084 Views)
While I have never encountered the problem, there is anectotal evidence from postings here that under some conditions (?) you get this error unless you install runtime engines in chronological order or similar.
Maybe NI has a solution.
Message 5 of 21
(5,072 Views)
That would certainly be nice if NI had a solution. Apparently they don't monitor this stuff...
Message 6 of 21
(5,024 Views)
Did you check the KB link I gave you above?  It sounds like the same problem I dealt with and it's an easy fix.
Message 7 of 21
(5,014 Views)
From what I can tell, the KB article is about "Executable Version (7.1.1) Doesn't Match Resource File (7.1) Check Your Configuration", while this thread is about the inability to install the 7.1.1 runtime if 8.2 is already installed on the same machine.
I don't think the KB applies in this case. Did you post the wrong link?
Message 8 of 21
(4,997 Views)
The application I'm trying to run is looking for lvruntimeeng.msi, and all I can seem to find in the support section is the .exe version. Until this app sees what it wants it won't be happy.
Message 9 of 21
(4,976 Views)
Hi Everyone,
You cannot install an older version of the Run-Time Engine once you have a newer one installed. The way around this is to uninstall the versions of the RTE newer than the one you are trying to install, install the oldest one and then the newer ones in oder. You can determine which versions you have installed by going to the Control Panel >> Add/Remove Programs >> National Instruments Software and find then in that list.
On another note, the KB linked above does not relate to this issue.
Eli S.
Message 10 of 21
(4,957 Views)
