03-27-2008 02:01 PM
03-27-2008 02:30 PM
03-27-2008 06:00 PM
Ugh! ![]()
Yes it SURE would be great if NI could make all the RTEs backward compatible wouldn't it? Install the latest and all the old ones work too. It might be a bigger install package but that option would be nice to have available.
03-28-2008 04:35 PM
03-28-2008 06:22 PM
@Eli_S wrote:
You cannot install an older version of the Run-Time Engine once you have a newer one installed.
03-31-2008 08:37 AM
03-31-2008 12:41 PM
06-26-2008 10:42 AM
I've got a similar problem so I thought I would follow the instructions given. But I'm a bit confused. The vi I'm trying to run is asking for RTE 7.1.1, which is the version installed anyway!
When I try and remove the RTE engine as per the earlier post, it tells me that I must also remove the following :
NI Labview 7.1
NI Labview Application Builder 7.1
NI Labview SignalExpress 2.0
NI-DAQmx 8.5
Is that really going to help? I've tried asking it to repair but that didn't work. So what should I do now?
Julian
06-27-2008 10:28 AM
06-27-2008 04:18 PM
Eli
It's a VI, not an exe. Anyway, I managed to get the problem sorted.
Because we install from the server, rather than a CD, the LV installer prompts to ask where to find the drivers folder. I had previously pointed it to the newest version I could find (usually a sensible option with most software, but apparently not with LabView!). Eventually I discovered a lurking folder called "Drivers.old"
So I completely uninstalled Labview and all associated NI stuff, and reinstalled, pointing the installer to the aforementioned folder, and it all works OK now.
Bit of a hassle though, and bizarre behaviour! It cost me quite a lot of time to find the problem, and fix it. Still, finally I can talk to the hardware, which is a relief because the example LV vis provided by the manufacturer (CAEN) didn't work at all! But I never wanted to be an industrial automation specialist anyway. I always wanted to be... a lumberjack!!! Leaping from tree-to-tree as they float down the mighty rivers of British Columbia etc etc... oh no, who are these men in white coats? Aaarrghhhh!!!
Thanks for replying!
J
