App. with source distributions work on XP pro but dont work on XP home
Hello!
We built application and a number of source distributions driving from apllication. It works fine on PC with Windows XP professional, but return error when we try to run it on XP home edition. We test it on 6 PCs. How to use application on XP home?
PS LV 8.5
(2,650 Views)
The LabVIEW Release Notes do not mention any limitations to a specific edition of XP (except 64-bit).
What error do you get?
(2,643 Views)
When app try to run startup VI from source distribution, it returns error something like "VI is not executable" (error 1003).
(2,635 Views)
Bad thing. There are several articles that deal with error 1003. You can search for 1003 on ni.com.
However, I do not see a relation to XP Home. Did you install the same LabVIEW Run-Time Engine on all PCs?
(2,619 Views)
Since you consistently cannot get this to work under XP Home, then clearly you must be using something in the OS that exists in XP Pro, but does not in XP Home. So, the question is what? You'd need to tell us more about what your application does in order to determine that.
(2,607 Views)
Thank you very much for help, problem is solved after reinstallation of run-time engines.
(2,604 Views)
This is what I guessed/expected.   Nice to hear that you managed it.
(2,598 Views)
