Plug in architecture
I am trying to create a vi that would have different options available, depending on an ini file.  Each option is associated with a vi that would be called dynamically and shown in a subpanel.
I wanted to to do this, because I want a simpler way to distribute new feature.  I thought I just need to send a single vi to the users, but I am wrong.  My dynamically called vi also include vi from toolkits and source control library.
What is the right way of doing this?  A source distribution?
Kudos and Accepted as Solution are welcome!
(2,656 Views)
You could use a packed library. Alternatively you might want to consider building an exe. Much easier to distribute. Plus you can build an installer.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,640 Views)
I need to play with those options a little, thanks!
(2,624 Views)
