SIT的问题
做matlab和labview联合仿真时,遇到这个问题:
This host VI is missing some components required for execution.  You might have modified or removed some block diagram components with green labels.
Complete the following steps to address this issue:
1) Close the SIT Connection Manager dialog box.
2) Select Tools籓ptions and select the "Block Diagram" page.
3) Ensure the "Delete/Copy Panel Terminals from Diagram" checkbox does not contain a checkmark.
4) Delete the entire block diagram of the host VI.
5) Place a checkmark in the "Delete/Copy Panel Terminals from Diagram" checkbox.
6) View the block diagram and delete the controls with green labels.
7) Generate the host VI again.
就是不小心把带绿色标签的组件删了,然后就连不起来了。解决方法也在上面,主要就是第二步有个Tools籓ptions ,不知道是啥玩意,求大大帮助~
(3,042 Views)
it sould be Tools Options
Yupeng J.
(3,020 Views)
这个tools optiongs在哪?我怎么找不到呢?
(3,016 Views)
please click Tools then select Options in the pulldown menus
Yupeng J.
(3,004 Views)
