Appear to lose connection with the Shared Variable Engine
The functions I was referring to earlier were the DMM and Oscilloscope VIs.  I have since removed these from immediate execution and only have them execute upon a user button press.  This has improved performance somewhat, but not eliminated the issue.  Other things that seem to improve performance:
  • Inserting 1ms Waits on every iteration of every FOR or WHILE loop
  • Removing the portion of code that periodically reenables and then disables the screen refresh (my original intent was to prevent too much drawing as many indicators would update)
  • On the event case structure, changing each case to Lock Screen Until Case Has Completed Execution.
Dan
Message 21 of 22
(549 Views)
thisisnotadream-
All of the things you posted will help the processor work function better.  Is it possible for you to post a smaller version of your code that recreates this?  The whole code will not be nearly as beneficial for troubleshooting as the smallest version that represents what you are seeing.
Mike S
NI AE
Message 22 of 22
(529 Views)
